Date:    7-1-2016
Number of Hours:    4.50
Brief Description:    Cable brace attach points
Today was a day of catching up and cleaning up items that had been on the back burner for a while. I remade a few of the wing fittings before epoxying them permanently into place.
The aileron hinge brass tubing was also epoxied in.
Holes drilled for the horizontal stabilizer cable attach points and 1/4" aluminium tube reamed out to 3/16" with the drill. The tubing was cut to fit between the attach points on the gussets, JB Weld applied to secure them. Whilst drying I had threaded rod inserted to keep everything aligned until dried.
