4-9-2016 |
1.00 |
Sanding |
Got onto a great idea for sanding blocks using off the shelf sanding belts. Here's a link. http://www.instructables.com/id/Simple-Belt-Sander-Blocks/ Made mine even simpler by cutting and rounding 75mm x 35mm pine to the exact size of a snug fitting belt (457mm). Ribs placed back in the jig for the final time whilst the trailing edges are all sanded to the exact same length then stacked 26 high. |
