Date:    8-17-2012
Number of Hours:    3.90
Brief Description:    Continued with the center section
Worked on the aft bulkhead of the center section, mounting the control stick support brackets and then installing the sticks with the link between them. Putting this all together is much easier with the bulkhead on the bench than standing on your head in the cockpit later. The assembly was then removed intact for installation later.
