Date:    6-11-2012
Number of Hours:    1.30
Brief Description:    A few piddling things, but necessary
The last couple of days I have taken a little time here and there to debur the holes on the bottom right wing skins. I found that the wing skeleton makes a good support for the skin while deburring said holes. When I finally finished both sides of both skins, I noticed that I had not installed the nutplates for the access panels, so drilled and deburred the holes, countersunk the rivet holes and dimpled the #8 screw holes, and riveted in the 8 nutplates. Next will be to put this skin away and break out the inboard skin and do the nutplates for it, but it's getting too late for that tonight.
