Date:    11-29-2007
Number of Hours:    1.10
Brief Description:    Spar reinforcing strips
Just did a little piddling tonight, polished the spar reinforcement strips on the scotchbrite wheel, and clecoed them on to the rear spar. When I got them into the good light downstairs (my drill press in which the Scotchbrite wheel is mounted is still up in the garage, the airplane factory is downstairs in the basement), I wasn’t happy with the overall finish, so will polish them some more before priming and assembly. Found out that I did not order enough 1/8” clecos, so a couple of days ago, I placed an order for 50 more, along with a C-frame dimpler, dies, some small air line fittings, fluting pliers, and some “oops” rivets that I hope I won’t need.
