Date:    6-9-2011
Number of Hours:    1.80
Brief Description:    Riveted the top skin trailing edge
Took a break from work this afternoon for a while and squeezed the rivets along the trailing edge of the left top wing skin. Most went just right, but there are 3 or 4 that I plan to drill out and redo. First I will build a stand to hold the wing with the chord vertical and the leading edge down, so it will be easier to drill in that position instead of with the wing flat on the table and the skin on the bottom.
