Date:    4-18-2010
Number of Hours:    1.30
Brief Description:    Added sealer to the left tank
Instead of starting on the baffle for the left tank, I decided to put some more sealer on the inside at the rib-skin joints and the inside end of the rivets, to try to eliminate the possibility of leaks. I am so sick of fooling with leaks I could just..., whatever. When I ordered the new skin and ribs for the right tank, I also ordered a fresh can of ProSeal to avoid the possibility of using sealer with an expired shelf life, and placed some in the tank on top of the previously installed sealer. I still need to turn it over and put more on the top side joints.
