11-6-2010 |
3.00 |
Finished the cutout on the left wing |
Continuation of November 6 work. After a lot of filing, sanding, and scotchbright work, the corners came out passable, but is not a true circular radius. Bugs me, but not enought to build the leading edge again. After finishing the cutout, I drilled the adjacent rib webs for the #10 nutplates that will support the light mounting bracket, then match drilled the aluminum strips that will hold the lens in place to the wing skins. Called it a night then. |
