2-14-2014 |
0.80 |
Stick bottom |
Today I had the bottom piese welded to the stick. You can see the results in the photos. Weight turned out to be 276 grams (9.2 oz) without the handle. This is the first trial. After welding the bearings, it will be as it is if I like the results. |
