Date:    1-7-2018
Number of Hours:    3.00
Brief Description:    Cutting right aileron out
I cut the ribs and the wingtip bow and separated the aileron from the right wing. I cleaned and sanded the remaining parts. I re-installed the hinges. I tested for movement, everything proved to be ok. I tested the position of the control horn and pulleys. They work perfectly so far.
