Date:    11-10-2015
Number of Hours:    4.00
Brief Description:    Fuselage bearings
I ground the angles on the bearing cylinders instead of filing. Easier and cleaner surface. I test fitted them on the jig and the 8mm rod was free to rotate. This means the holes are in allignment.
