4-4-2020 |
1.00 |
Wing Rib lay out on spar |
Started fitting the rear ribs to the front spar Marked rivet linea and drilled thru factory holes Ribs 1&6 needed the top notch cut. Some ribs need hammered on the ends to fit/match the spar |
