3-23-2020 |
1.00 |
Aileron bell crank support |
Match drilled the supports, then rough cut on the band saw. Cleaned up edges on sander Made spacer block from plywood and scrap sheet metal to set gap between supports when clecoing to RR#7 and 6W6-10 Removed spacer block and inserted belcrank assy to verify everything is tight, but moves freely |
