Date:    2-9-2020
Number of Hours:    1.00
Brief Description:    Attatching spar tip
When I butted the spar tib against the end of the caps, it was angled up, so I clamped "L" brackets to each side of the spar to keep it aligned while I drilled the holes.
Layed out the l angle on the end
Get all nose ribs in position.
All rib flanges point outboard except for NR#3, it faces inboard
