Date:    2-23-2020
Number of Hours:    1.50
Brief Description:    Trim tab fitting
Did alot of sanding and filing to get the opening just right,
Fitting the channel was a chore. Once positioned it was not the same height as the ribs.
I made a shim for each corner to help to help the skin transition without a big joggle in the corners
I did not see any dimensions on the drawing for where to locate the servo, so I put it on the center line.
