Date:    2-17-2020
Number of Hours:    1.00
Brief Description:    Aileron
Made a trip over the weekend to Mexico to pick up the piano hinge type skins, and hinges.
I use a small block of plywood with a thin layer of aluminum double sticky taped to one side to make the 13mm block, slightly over 1/2" thick
Marked the skin for the 5mm offset of the first rib
