11-23-2007 |
1.50 |
HS Final Assembly |
Riveted the rear spar assembly to the inspar ribs using the blind rivets. The instructions say to put the manufactured head of these rivets on the spar and not the rib. How the heck could you do it any other way? You sure can't get a rivet puller through a lightening hole to pull it from inside the HS. Started riveting the spar to the skin, finished up one side. |
