Date:    12-12-2018
Number of Hours:    1.50
Brief Description:    Control stick base
Worked on fitting the control stick base into the control stick column. Had a bit of an issue on the left side and ended up with it a hair to short resulting in a bit of slop. I fixed this by using an appropriate washer to shim the base. A lot of people complained about the slop due to the bushing being a smaller diameter than the pivot tube, but mine fit really well.
