Date:    11-30-2016
Number of Hours:    2.00
Brief Description:    Tailcone wiring
Worked on the wiring for the elevator trim. I put a hole in the side of the elevator trim mount and put a bushing in it to run the wires out from the trim motor. Then I added cable tie mounts to hold the wires in place. The wires for the aft nav lights will be run with these wires and tied together for added support
