Date:    7-29-2015
Number of Hours:    3.00
Brief Description:    Aileron trim wiring
Making the connections from the aileron trim wire (5 wire shielded) to the trim unit. I am using the D-Sub pin connection method. I also connected the springs to the arm of the trim unit. This was not easy, the springs are very stiff and it is a tight space to work in.
