8-5-2007 |
3.25 |
Rudder Skeleton |
Finished drilling the skeleton components. Deburred the skins, then clecoed the whole assembly together. Match drilled all the appropriate skin holes. I need more clecoes! I was unable to cleco both skins to be drilled at the same time. Of course, it all needs to be flipped over anyways so after finishing one side I pulled enough clecoes to do the other side. The trailing edge was drilled last. Pictures: DSC03476 - DSC03477 |
