Date:    8-9-2016
Number of Hours:    2.25
Brief Description:    Gear mount install
Worked on installing the right gear mount. It is a very tight fit and not easy to get all the bolts in. The brace that is bolted to the front rib was very difficult to get lined up and there needed to be tension on the bottom row of bolts through the spar carrythrough to draw it into position.
