3-19-2016 |
4.25 |
Fuselage mid side skins |
Bending of the fuselage mid side skins and fitting to the fuselage skeleton. This was not as hard as I thought it would be but it does take a lot of elbow grease. The sharp bend at the forward part of the skin was actually very easy to do and lined up perfectly with the pre-drilled holes. The aft part of the bend is more difficult as you need it to be gradual and it is easy to kink the skin if you aren't careful IMG_0431.jpg - IMG_0434.jpg |
