Date:    2-23-2009
Number of Hours:    3.50
Brief Description:    Riveting the rib halves to the skins
I noticed that the rib halves are opposite (top and bottom), from right to left. When I clecoed the rib halves together, I labled all the larger pieces to go on the bottom. I assumed that I final drilled the right elevator with the ribs backwards. I was so sure that I called Van's to see if it was OK. I realized that I really did it right when I assembled the whole elevator. I had already riveted two pieces on. I was glad that I really did it proper and I removed the two pieces to do it right.
Here is a link to show what I mean in the drawings: http://www.myrv10.com/Plans/RV10_Plans_sec09-pg11.html
