Date:    10-15-2005
Number of Hours:    6.00
Brief Description:    Finish engine wire
Section 11 date 10-15-05 Drill the holes in the firewall for the wires then I used a fire shield to cover the rubber grommet. I located the wire on the upper edges of the firewall. I connected the senders and the alternator ran the wire for the starter. I installed the carburetor heat cable (Image) 100-428, 100-430 & 100-431)
