11-10-2005 |
2.00 |
Cowl Trimming |
Section 12 date 11-10-05 I trimmed 1/16” off the upper edge of the cowl to have 3/16” clearance from the spinner back plate. I finish trim the cheek area with a sanding block. I drilled the left side cowl hinge and taped the left cheek to the fuselage.I finish drilling the right side upper cowl hinge and drill the cheeks to the fuselage. No images |
