Date:    10-21-2002
Number of Hours:    25.00
Brief Description:    Started Ailerons
Chapter 7 Wings Date: 10/21/02 Started the Ailerons today. The construction is the same as the rudder and elevators. There are ribs on the ends and the stiffeners are pre-made after dimpling and priming I started to rivet the stiffeners on t the skin. I used George Lieders break to finish the radius in the skins. Next is to build the aileron spars drilling the lightening holes, fitting to the Skin and dimpling. Primed and assemble both ailerons. No images available
