Date:    4-28-2006
Number of Hours:    3.00
Brief Description:    Cowl to spinner build up
Date 4-28-06 Sec 12I finish my attempt at being a bondo sculptor. The area behind the spinner needed to be built up about ¼” I used foam with epoxy resin and 9 oz glass and I finished it up with polyester filler. I removed the engine case for overhaul and it should be back in two or three weeks. Now I can start the painting process. (images) 00-378 00-380 &00-381
