Date:    7-4-2002
Number of Hours:    1.00
Brief Description:    Straighten Rear Skin
Realign rear skin to Rear Zee and Spar to insure proper alignment after drilling. Had to make some slight adjustments: Remove Clecos from S9. Pull skin down to cover rear zee. Redrill second hole from the bottom of skin at S9. This will need an A5 rivet when complete. Success! All lines up with minimal changes.
