Date:    4-29-2013
Number of Hours:    1.50
Brief Description:    Continued Removing Protective Film
Removed the blue protective film from the inside surfaces of the rear stabilator skins. I used a pencil-type soldering iron to separate the film into strips so that it would peel off easier. I found that strips about 3" wide worked best. This is a time-consuming process!
