4-28-2013 |
1.50 |
Removed Protective Film from Skins |
Removed the blue protective film from the outside surfaces of the rear stabilator skins. I used a pencil-type soldering iron to separate the film into strips so that it would peel off easier. I found that strips about 3" wide worked best. This is a time-consuming process! |
