4-6-2013 |
2.00 |
Drilled and Clecoed #30 Stabilator Bottom |
Drilled and Clecoed #30 the bottom of the Stabilator. Discovered in this step that I had mistakenly drilled and clecoed the HS servo tab hinge doublers to the rear spar. This step should have been delayed until after the servo tab hinges were fabricated. I will order new doublers. |
