4-3-2013 |
0.00 |
Drilled and Clecoed Right Forward Skin to Ribs |
The photos for this log entry show the right forward skin after it has been drilled #40 and clecoed to the forward ribs. On the top side of the right forward skin where the skin wraps around the most inboard of the ribs I noticed a slight "bump" where it appears that the edge of that rib was not sufficiently trimmed. I marked the area on the skin and on the rib (since it was an inboard rib it was accessible from the opening). When I remove the clecoes for deburring the skin I will tap out hte small "bump" in the skin and trim the rib. |
