Date:    10-5-2017
Number of Hours:    1.50
Brief Description:    Attach hoses to fuel drain line (46-16,17,18,19)
Attached the hose and routed it out and down. I plan to cut the end to size later, once I’m sure I’m done moving it around.
I proceeded to remove the lower banjo bolt and just a warning here, there is some oil in the engine, so be prepared in advance to catch the oil. It also says to assemble the new fitting from Rotax with dry threads, but it will take a while before all the oil drains out. I rigged up a cup underneath to catch the drips while I worked on other stuff. Later I came back and wiped down the threads until dry, then used Loctite to attach fitting.
Next job was to make the grommet and install the rectifier regulator. The instructions come with what looks like 2 identical pages on where to drill holes, but my assembly was already drilled, so I ignored those drawings. Attaching the wires was straight forward.
