Date:    10-3-2017
Number of Hours:    0.50
Brief Description:    Fuel Drain (46-16)
Bending the fuel drain tube was a little challenging (step 5 & figure FF-01223), but it’s pretty flexible and small adjustments can be made by hand. In picture one it looks like the entry point is off slightly, but that's due to the camera angle. I also rounded the ends as described and (I’m sure pure luck) got the length right. It worked pretty well to bend the tube first, and then cut to the right lengths.
