9-26-2017 |
1.00 |
Fuel lines and banjo bolts (46-07) |
This took a little while to take apart the banjo bolts and flip the bracket to the fwd side. The bracket was really tight on the tube, so I ended up having to spread it apart a little to get it to rotate. I also recommend re-attaching the lower banjo bolt before final tightening the Allen bolt. The fuel lines are really stiff and the bracket may need to move a little to get it all back together. Anyway, that's done. |
