Date:    7-1-2018
Number of Hours:    1.00
Brief Description:    ADS-B Atenna Install (53-11)
Since the tank is out and I have access to the rear of the plane I read ahead and installed the bracket and antenna for the ADS-B. With the help of Cyndi again I positioned the bracket and drilled the holes while she clecoed from underneath. I used tape to mark on the bracket to mark the center of the 9/16 hole and drilled it with the #30 as directed. Then I went underneath with the step drill to cut it to size. I must have gotten lucky, because it all fit nicely. I'm not sure why they wanted the wire for the ADS-B to be right under the control cable, so I added another tie wrap to make sure it doesn't touch.
Also as I was thinking about closing up all the floor panels it occurred to me that I hadn't painted the flap arm position stops. It's been in place for a while, but I had noticed it need to be painted, so I pulled it off and painted what I hope to be the last part of the interior.
