Date:    4-28-2018
Number of Hours:    0.50
Brief Description:    HS Front Spar Service Bulletin (SB 18-02-02) Log
With the help of Cyndi and Scott, we were able to get the stabilator back on without too much difficulty. It’s definitely a tight fit and it took a couple tries to get the washers sandwiched in correctly. I did end up having to loosen the cables in order to get them back in place. Guess that means I need to purchase a tension checker or borrow again. I think this wraps up my Service Bulletin 18-02-02 as complete.
