Date:    3-23-2018
Number of Hours:    1.00
Brief Description:    Install canopy catch (34-25)
While I was waiting for the service bulletin parts to show I decided to finish up some old projects that I haven’t gotten around to, like the canopy latch. I painted it a while ago, but never drilled out the rivets to install it. I also took the opportunity to tighten the tube around the latch shaft to give it a little more friction. It was moving too easily and would fall out of place under its own weight. Installing the catch was pretty easy and the cherrymax rivets worked fine.
