Date:    8-24-2017
Number of Hours:    0.50
Brief Description:    Fule neck plate nuts (37-07)
As mentioned previously, I used a clecoe clamp to hold the plate nut flush to the surface and rivets to position it. Because the clecoe clamp was right next to the rivet, I used the small diameter rivet set in the squeezer. This worked out really well.
