Date:    5-20-2017
Number of Hours:    4.00
Brief Description:    Lots of sanding sanding (34-15)
After pulling the peel-n-ply off, I spent several hours trying to get it as smooth as possible. I'm using 60 grit with small wooden blocks to sand the sides. I contoured a wooden block for the transition on the top side. This fiberglass is tough stuff, so it's taking some time to get smooth. I need to add some micro balloon mixture to the low spots to finish it up. In the meantime I wanted to locate the bolt holes.
