Date:    4-25-2017
Number of Hours:    0.50
Brief Description:    Cut foam blocks to canopy (34-13)
I marked the angle on the foam blocks and then just used the hack saw to cut down the line. The foam cuts really easy, then I sanded it smooth to match the canopy arm contour. I only had a 3/4" step drill so I went with that for the bolt hole and it seemed to work just fine for now. I also worked the foam back into the skirt curved portion which cut a groove and made a nice tight fir for the foam.
