Date:    1-6-2017
Number of Hours:    1.00
Brief Description:    Remove damaged ES-00078 connector (30-03)
I found a cheap small screw driver that I ground down to make a removal tool for the connectors. I damaged the ES-00078 when I tried to install the right wing. I have another one on order, but I need to get the wires out of this one first. The new tool seemed to work fine. I slide it on side, then while pulling on the wire, I slide it in the other side and the connectors slide right out.
