12-31-2016 |
2.00 |
Horizontal stabilizer control cables (32-13) |
I proceeded with the fwd end cable install for the horizontal stabilizer. No problem attaching the cable ends, but I should have done some research first and thought about it a little ahead of time. It's much easier to slide these cables in from underneath and sliding the fwd...as opposed to attaching them and then trying to route them back. It can be done, as I proved, but it was a challenge. Need to pay attention to which cable goes through which holes. I think I have it right, but what I did was rout the left cable through the holes that were must left (no matter which height), then route the right cable through the holes that were slightly to the right side. I'm going to hold off on mounting the horizontal stabilizer until I get the wings installed and torque arms attached. The horizontal stabilizer will take up a bunch of room in the garage. |
