I needed some more hands and a warm & no wind day to pull the plane out and install teh wings and set the torque arms...so I decided to jump ahead to the rudder cable install. I love this cable...I've nevver seen cable be so flexible. Typically it gets cincked and has some spring like curve to it, but this is more like rope. Anyway, after I refamiliarized myself with the bulk head identifiers I was able to slide teh rudder cable though all the right spots and clamp down the plastic tube through the fwd tunnel area. I alos created the rudder stop fixture used the set the pedals in the right spot. I had seom scrap MDF that worked great. The instruction suggested using left over crate plywood, which I have, but nailing into the edge of plywood is not very strong, so I opted for the scrap MDF.
