Date:    12-23-2016
Number of Hours:    2.00
Brief Description:    Installed brake lines (32-02)
I made a couple wheel chalks to keep the plane still as I climb in and out. I attached the brake fluid reservoir and last of the brake lines. Then I proceeded to order some brake fluid...no hurry at this point. I was thinking about aeroshell 31, since it flame resistant, but it only comes in gallon size, so I went with aeroshell 41 (quart size). I'm not happy about how all the brake lines fit in underneath, but it should be functional. I may come back and tweak some of the lengths so they match up a little better, but that means getting some more tubes and connectors. Good enough for now.
