Well this was a big day, I put the plane on its feet, installed the brake lines and vertical stabilizer. I had skipped ahead to section 35 to get the landing gear installed, then I went back to section 32 for the controls, but the first step in 32 is to go back to 11-02 and install the tail feathers. It was real tricky to get the upper hinge bolt installed for the rudder. After I got all the washers into take up all the space then all I had to do was install the nut on the bolt (very tricky). The technique that worked for me was to tape the nut and washer to my finger, then hold it underneath in place while I managed to get two finger in on the head of the bolt to turn it enough to get the threads started.
