10-10-2016 |
1.00 |
Run WH-00046 wire harness (31B-05) |
Started routing the WH-00046 wire bundle through the fuselage. I taped each wire end to the bundle to make it easier to pull through. The instruction don't specify which location to run the wires, so I chose the bottom holes. |
