Date:    9-29-2016
Number of Hours:    0.50
Brief Description:    Run ELT line (31B-03)
I turned the fuselage on its side and started routing wires. It's not clear from the manual pictures which grommets to use for each cable, so I just chose some near the bottom skin. I started the ELT (phone) line from the right side on the conduit and worked it fwd. It's stiff enough to push through the conduit without using one of the pull strings.
