Date:    5-2-2016
Number of Hours:    1.00
Brief Description:    Prep for upper firewall attachment (29A-03)
Per the directions on 29-02, I dimpled the lower flange, but I noticed that there were 2 holes that were dimpled on the shelf, but called out in the figure. Also the next page called out to use 8 flush rivets, but only six holes were called out to be dimpled. So I went ahead and dimpled the other 2 holes (8 total) on the lower flange.
My order came in from sky geek with the fuel tank sealant and a mini plunger, which didn't fit my caulk gun. After a little thought and a look around the tool box, I found a basketball pump that would fit nicely in between. Now I just need to mix 10:1 the two compounds...and of course my digital scale doesn't measure in small enough increments...so you know what that means...another internet purchase. I justified it by saying it will work in the kitchen as well....honey, this is for you...she didn't fall for it. Next step is to attach the upper firewall.
